BSA B40 clutch adjustment
evo boy
Morning all could anyone please tell me how to set up the 4 clutch springs? I know on some you tighten them all the way then back them off 4 turns but not sure about the bsa. Also should they be wired once set up?
Many thanks
On 6/25/2019 at 7:56 AM, jon v8 said:
Be a good idea to get hold of a copy of the Rupert Ratio engine manual,everything you need to know is in there.
http://www.ratiopublishing.co.uk/
I'll do that thank you as I bought a Haynes manual but it's not very good. Which one would you recommend for a WD B40?
Edited by evo boy
Adjustment
2 hours ago, evo boy said:
Also I've fitted the clutch basket clutch ect back together but the outer part of the basket seems to have in and out movement is this normal?
Many thanks
Take or leave advice, but at least have the courtesy to acknowledge it.
Hi b40rt sorry if I offended you it wasn't meant to. Thanks for the advice its much appreciated.
  • Thanks 1
