Pre mix
yam175
47 minutes ago, timdog said:
Interesting article on classictrial.co.uk under heading technical then 2t explaining how different oil is now compared to back when twinshocks were new. Recommends 70:1 for air cooled
I will give it a read thanks
These engines were designed when the oils were what was available at the time. Now modern oils can be used more sparingly, so the mix ratios can be reduced. However those newer ....technical.... oils can still be mixed at the old ratios 40 or 50:1 purely for peace of mind....I run my 348 on 50:1 synthetic.
13 hours ago, yam175 said:
Semi or fully syn
I use Silkolene comp 2 which is synthetic
I did use Castrol power 1 which also worked well
it's also worth noting that Castrol and some other manufactures state a maximum of 50:1
Edited by suzuki250
