montesa 315r fuel tap
myatt
drill a small hole in the tap & use a small zip tie or key ring to give easy purchase. Quite easy mod.
(BTW Be careful if you decide to unscrew original tap from tank (M6 screws).  Captive nuts moulded  into tank can let go.& you'll have a bit of a carry on to sort it all out. You'll also need some fancy epoxy to re set them)
  • Like 2
