Gwill007 Posted February 1, 2020 Report Share Posted February 1, 2020 (edited) Can anyone advise. Im after as much information as possible on the bike I am restoring. I know it is a Fantic 200 FM350 but any additional info would be welcome. The chassis number is DGM 19461 OM also Fantic 350 stamped along side the chassis number, engine number 0001620 and the date stamp under the tank is 1979-9 What I would like to find out if possible are all the numbers matching and its date of manufacture. I bought the bike as a non runner with a box of bits. Thanks in advance Edited February 1, 2020 by Gwill007 1 Quote Link to comment Share on other sites More sharing options...
furse Posted February 1, 2020 Report Share Posted February 1, 2020 There should be more numbers on the frame, they are faint you may need to remove the paint, run along side the dgm number, why do you want to know the year? They are all the same really, 1 Quote Link to comment Share on other sites More sharing options...
Bilko Posted February 2, 2020 Report Share Posted February 2, 2020 Might be more info on site http://www.fanticmotor.asso.fr/r02_f03.htm 1 Quote Link to comment Share on other sites More sharing options...
Gwill007 Posted February 2, 2020 Author Report Share Posted February 2, 2020 15 hours ago, furse said: There should be more numbers on the frame, they are faint you may need to remove the paint, run along side the dgm number, why do you want to know the year? They are all the same really, I did not notice any additional numbers when I got the bike. The frame has now been powder coated so that will not be coming off. I just want to find as much info on the bike as possible. Cheers. Quote Link to comment Share on other sites More sharing options...
apb Posted March 5, 2020 Report Share Posted March 5, 2020 It looks like your date is about right. The earlier forks with the single pinch bolt but looks like the later steering head set up. I don't think the later post 80 models had the tool box brackets either. Looking good though, is the frame ral 3000 or 3020? Quote Link to comment Share on other sites More sharing options...
