Montesa 248 oil from exhaust
Robert 65
57 minutes ago, Robert 65 said:
Hello
I was having oil coming out of the exhaust.
I've changed the crankshaft seals
No improvement
Petrol/oil ratio not the problem
Any thoughts
Perhaps the silencers are that clogged up with oil ?
Edited by rotors7
The oil you see is probably condensed vapour/smoke from the combustion process. Modern two-stroke oils can be so good at resisting burning that they can cause what you are seeing. Once the sound absorbtion material in the exhaust is fully wet with this oil and it can't hold any more, it will start coming out wherever it can. It really doesn't do anything except make a mess so if you can manage the mess then you don't have to do anything. If you rode the bike hard enough the exhaust may get hot enough to stop the oil condensing inside the exhaust. Also if you ride it hard enough with oil already in there, it may clean it out to some degree. If you decide to clean out the exhaust by taking it off (it can be cleaned out a few ways when off the bike) but still continue to ride in the same manner, it will continue to fill up with oil. I've seen bikes with a drain line at the low point and when the bike is parked, they put a container under the drain line to catch what comes out.
I have had two strokes do this, remove exhaust, tip it out. It builds up over time, I used to find after riding my TY 250 on the road at higher speeds the oil in the system would get really hot and smoke like crazy even for a while after turning off the motor.
Morning
Many thanks for your reply.
Feel much better reading this.
It's been stood in garage for years
Has mentioned I changed the crankshaft seals that were rock hard.
New oil,plug, points etc
Started straight away.
I'm running 30 to 1
What oil should I add to the petrol,?
Best regards
Thank you for your reply
Never had this running before
Owned for years
Feel happier now
Thank you
1 hour ago, Robert 65 said:
25 to 1 what oil should I add to the petrol
I'd run it at 50:1, 100ml to 5 litres of petrol using a quality semi synthetic 2 stroke oil.
Even at this reduced rates it will smoke and build up in the crankcase and exhaust. As said above, it needs decent run to get some heat into it to burn off excess, or cleaned out and repacked if this isn't possible.
Edited by b40rt
