Power Advise
Stevesherwin
I'm currently running a Gas Gas txt 280 pro Racing with a fly wheel weight and slow throttle but it just wants to run away with you all the while i feel I'm constantly battling with it and holding on I'm looking to change it ASAP for something thats less aggressive can anyone recommend anything I've heard the betas are a little less aggressive?
How long have you been riding a trials bike ?
Do you have mates with trials bikes and experience or a local club ?
Before you get too concerned about changing your bike I suggest you get some advice on setting it up, it may just need the engine tuning and the clutch and brake ‘bite’ points setting up to make it more rideable.
  • Thanks 1
You can quite easily make a softer power by increasing the thickness of the cylinder base gaskets. There may also be a low compression cylinder head available for your model. Both should be relatively low cost and something you can do yourself if you're half mechanically minded. Give John Shirt motorcycles a call as they are the Gas Gas specialists, presuming you're in the uk
  • Thanks 1
Before you change it for something softer, get the ignition timing retarded by about 4mm first.  That is 4mm not 4 degrees.  That will tame it down.  When you become more confident you can get it put back to where it was.
  • Thanks 1
The GG 280 is one of the fieriest bikes on the market. Try a 250 of any make to compare. Lowering the compression will make your 280 quite a bit softer at the bottom so it will not pull off so sharply but you will still have a lot of torque by comparison with a smaller motor. It is not a good place to be, worrying about the bike running away with you. Better to boss a smaller engine and then move up.
  • Thanks 1
Most of my riding buddies and myself included all put a smaller front sprocket on them to slow them, 11T is standard but they make a 10 and a 9.  I use the 10 and it makes a big difference, also makes second and third gears much more usable as well
Putting a smaller front sprocket will indeed slow it down, but at the same time it will actually increase both power and torque!
  • Thanks 1
The ignition timing isn't adjustable on this bike,the stator doesn't have slotted mounting holes.Shame ,it would be a cheap and easy way to calm it down.I suggest if you really like the way it rides other than the power,sell it and get the 250 model
