Sherco Fuel Tanks
matgriff
Hi, does anyone know the type of plastic used for Sherco fuel tanks circa 2004 ?
I’m assuming it’s HDPE , high density polythene ?   I have a little sherco 50, and i’m going to plastic weld the fuel tank around the petcock area as it’s damaged and had previously been fixed with Epoxy .
Thanks
I had a 2002 with a translucent tank and the tank grew over time.  I ended up having to slot the mounting hole and it got harder and harder to push down between the tubes.  I read somewhere that it is the alcohol in US gas that causes the expansion.  I don't think HDPE does that.  Does it?
Hi don’t know , maybe the ethanol in US fuel ? this tank is also a translucent type material , it’s damaged slightly around the petcock area, I’ve removed the fixing part , just need to weld up the small splits , but it’s important to get the right filler rod material , Thanks
