singesavant Report post Posted February 23 Hi there, My 2017 raga after I change gear box oil from 10w30 to nils which is way thinner is now slipping. In 4 th and 5th couldn t get engine full rpm and no motion... I added 50 ml from the 300 ml and it made the clutch working fine again... yet I figure I would have to check and most probably change the clutch disc pack which I have order now. I got info than finger height should be at 22mm but how should I measure it? Disc pack is supposedly to be at 8.5 apparently... Thanks for your help Davy Quote Share this post Link to post Share on other sites
anotherfive Report post Posted February 23 Hi. Where have you got your info from as it doesnt match what i have. Pack thickness should be 9.75 to 9.80 mm and finger height should be 16 to 19.5mm. Finger height at point of finger down into basket . Quote Share this post Link to post Share on other sites
singesavant Report post Posted February 23 Thanks for your input i will have a look on mine. Got info from dherbey moto in france they usually re really good advices... Quote Share this post Link to post Share on other sites
singesavant Report post Posted February 24 (edited) On 2/23/2021 at 6:55 PM, anotherfive said: Hi. Where have you got your info from as it doesnt match what i have. Pack thickness should be 9.75 to 9.80 mm and finger height should be 16 to 19.5mm. Finger height at point of finger down into basket . Hi anotherfive, I see from your profile that you own a gasgas 300 are u referring to the gasser clutch wise or are u talking about a trs mate? Rather make sure we re on the same page? and not comparing apples to oranges.... Tx Davy Edited February 25 by singesavant Quote Share this post Link to post Share on other sites
anotherfive Report post Posted February 25 Ah yes sorry. I'm talking gasgas. Adam the wanderer threw me!!!!! Quote Share this post Link to post Share on other sites
