Exploded view brake pedal
Tiewrap
Hi, in the exploded view u can see part 12 and it seems to me that the piece with the nut is on the inside.
On my bike it does not fit that way, only with the nut on the outside to get enough clearance for the brake lever.
Anyone has an (2016) that can have a look ?
Also there is a "powerbox" in the front under the air filter. According the drawings it is in a rubber grommet.  I assume it is a bit confusing and must be the grommet of the ECU. So is the powerbox in a rubber grommet ?
