Fantic 240 and 300 swing arms.
fourex
Can anyone tell me if these are the same, I thought the way the brake plates were held in place was different for a start and I would have thought some dimensions between the two would differ also. Thanks.
Both 240 & 300 Swingarms & frames are completely different. Having said that, the alloy swingarms from later models can be made to fit, but not a job for beginners, as a fair amount of engineering required, i.e  dural parts to machine on lathe, & lots of alloy welding  required. Got a 240 with a 245 alloy swingarm. Have also seen a 300 with a 245 swingarm fitted.
240 / 300 foot peg  lowering / relocation is a good mod.
240 fork angle mod also worth doing, as is beefing up headstock area plating, as its prone to flexing.
300 fork angle is pretty good as standard.
