2000 315 forks banging when topping out
ar22
my 315 has an annoying crack/banging noise on full extension
fork seals are good and checking the oil levels they seem fine as per the manual, oil was recently changed.
The manual does mention in the right fork section a "stopper rubber" I don't see it in any of the pictures or the parts diagram, any ideas ?
I also see that the left fork has a "rebound spring", this could be adding to my noises, do these generally give any bother ? I see it in the parts book but unless I am wrong its doesnt list it with a part number.
before a full striping I would like parts at hand or at least located as I dont want the bike off the road for long and although annoying its perfectly ridable.
thanks
1 hour ago, carl ekblom said:
If it is a Crapioli it should have a rubber bump stop at the leg where the spring is. As I remember, it was a form of rubber ring. I don´t remember any rebound spring in Crapioli but normally they act as rebound stops and should not give any problem.
sorry should have said they are Showa
