TY175 Replacement Clutch Cover
mcman56
Is the 52500 marked clutch cover the only one that will fit a TY175?  I found that the same gasket fits a RT100 so bought one off of Ebay but it is about 10 mm wider.  It is also 10 mm wider at the kick shaft area so would at least require a longer kick shaft.
https://ibb.co/f2vnmJ6
Edited by mcman56
pic issues
https://ibb.co/hYPZ1qn
<a href="https://ibb.co/hYPZ1qn"><img src="https://i.ibb.co/2ZDsYbL/TY-vs-96-RT100-cover.jpg" alt="TY-vs-96-RT100-cover" border="0"></a>
<a href="https://ibb.co/hYPZ1qn"><img src="https://i.ibb.co/hYPZ1qn/TY-vs-96-RT100-cover.jpg" alt="TY-vs-96-RT100-cover" border="0"></a>
[url=https://ibb.co/hYPZ1qn][img]https://i.ibb.co/2ZDsYbL/TY-vs-96-RT100-cover.jpg[/img][/url]
[url=https://ibb.co/hYPZ1qn][img]https://i.ibb.co/hYPZ1qn/TY-vs-96-RT100-cover.jpg[/img][/url]
Do picture links not work directly anymore?
Edited by mcman56
pic link issue
7 hours ago, feetupfun said:
Yes, also DT100, DT125 and DT175 ABCDE models clutch covers will fit on the TY175 and yes the kickstart shaft length is different. The DT type cover is also more robust than the TY175 cover
Are you saying that all of the DT covers will require a longer kickstart shaft length?
I'm saying that I believe ABCD models DT100, 125, 175 covers are all the same part. They changed the cover design with the E model. If you want to check that out for yourself you can look up their part numbers.
I just did a search on these forums on this topic and from that, it seems you can use a TY175 kickstart shaft with a DT cover, but need to make a spacer for the shaft to stop it floating towards the right, so that sounds like both shafts are the same length overall but have the shoulder that bears against the casing in different locations.
I have a DT175A motor that I can compare the kickstart shaft and cover from with TY175 parts if you want.
I'll spend some time with the parts lists.  Thanks
  • 1 year later...
