Broken shim in rebound side of marazocchi 40mm
garydwall
Screenshot_20230109_223639_Gallery.thumb.jpg.b2972e4565c8932c5173a6d852a69f12.jpgI'm struggling to figure out where the broken shim is from, it fell out when I released the sealing piston....
I've looked at some drawings but I still don't  see?
Any advice greatly appreciated.
The shim is approx 0.1 mm shim
10mm I.d
20mm o.d.
Edited by garydwall
  • 1 month later...
On 1/12/2023 at 7:47 AM, garydwall said:
Im trying a light piece of spring... might last a bit longer.  Screenshot_20230112_154505_Gallery.thumb.jpg.b3d3dfe469add2aa367d09eb18d21ab8.jpg
Gary, how is the spring holding up versus using wave washer? Can you provide info on what type of spring you used such as length, diameter, where you bought it, etc.? Thanks
