October 29Oct 29 Hi,My 2015 Gas Gas TXT 300 recently started to misbehave.It sometimes starts in reverse. Cold or hot it doesn't matter. It started gradually, first once in awhile, than more often and now half of the kicks end up in revers starting. Beside this, when under load with low rpm, right before stalling, it reverses and sends me backwards downhill.The only reason I can think of is ignition timing, therefore I went straight to the woodroff key which is in perfect condition. Next I checked all the timing components, stator, flywheel, pickup coil, ground wires and grounding points, all good. With the stator removed, I performed an engine seal test, both negative and positive pressure, again all good, cleaned the carb, changed the spark plug with a new one, opened the engine to remove carbon deposits, put everything together but to no avail, it does the same thing.Did anyone ever encountered anything similar before? Can a partially faulty CDI do this? Any ideas?Thanks. Edited October 29Oct 29 by Loop
October 30Oct 30 Have you tried shifting the pickup coil to retard the ignition? or are they set in position on a GasGas.
