ekbeanctr
  1. I am finally getting to the front forks and am needing some information on what's available out there. Is there a source for new springs for the 175 Forks, I am guessing after 41 years that the old ones are probably pretty well used up. Also the manual says to use 10W30 motor oil in the forks? Is it better to use the modern fork oils in 10W. I weigh about 180 Lbs and ride Novice class.
  2. Thanks, ordered one from there.
  3. I have heard that a common trick for making the clutch easier on the hand is to put on a clutch extension on the arm that's down on the motor. Does anybody know where to get those or how to make one? Thanks
