November 17, 200619 yr for those of you that run ATF in you gearbox can you tell me what make you use or what type i should get? have been using putoline but clutch seems squealy whith this stuff but ok whith motorex oil but cant get that easily enough round here, friend of mine use's ATF in his 07 but dont know what type it is as it comes from an anominous source!, any opinions on its use would be appreciated.
November 17, 200619 yr we run 3 125 gasgas on dexron 11 with good results. AC Delco is good, any vauxhall dealer will sell it.
