November 23, 200619 yr Hi, Im looking for a supplier of the two small oil seals located right at the bottom of the forks on my Ossa 350 1977. They are 16mm diameter, hole size 8mm and 2mm thickness. Im located in the North East of the UK, Anyone can help ? Vaughan.
November 23, 200619 yr Have you tried a local bearing factor? Can normally get all sorts of seals from these places
November 28, 200619 yr I've managed to locate a range of wierd and wonderful oil seals and bearings from my local provider CBS Rotary Power Motion Ltd Unit 14 Grandstand Business Centre Hereford, HR4 9NS 01432 276 630 most providers will stock a range of metric, single lipped seals, but in many cases you'll want double lips. Their distributors usually have them and be got hold of in a couple of days.
November 29, 200619 yr Author I've managed to locate a range of wierd and wonderful oil seals and bearings from my local provider CBS Rotary Power Motion Ltd Unit 14 Grandstand Business Centre Hereford, HR4 9NS 01432 276 630 most providers will stock a range of metric, single lipped seals, but in many cases you'll want double lips. Their distributors usually have them and be got hold of in a couple of days. Cheers, I will give them a call. Vaughan.
