Adding Coolant
Any tips on how to add coolant? The radiator is pretty well hidden and it looks like I have to move the radiator to do so??
I have used a squeeze bottle with a rubber hose in the past.
To be honest I have not checked it on the new one, suppose I should!
Historically, if you fill them they will puke out the excess, just enough to cover the cores, plus a bit, and they are happy!
Hope that helps! :chairfall:
The best thing I have found to fill the rad is a 60ml syringe. There is a guy who sells them on ebay for about
  • 1 year later...
just a question on how this works....do you inject it into the drain hole or up the breather pipe?
No take the cap off when cold and fill it there.
Under the tank.
