March 30, 200422 yr was at the local guisboro trial at weekend (hard i must say) n i was halfway through the trial i was jst messin bout goin up this step n slipped the clutch at quite high revs to hear this almighty load grumblin rattley noise comin from the gear box crank shaft sort of area. so after further in vestigation today i have drained the oil to have loadz of rubber like bits drop out with the oil. anyone think of what this maybe i was thinkin a seal somewhere? a freind seem to think ther might be a shock absorber behind the clutch that may have disintegrated after inspectin the clutch it makes a clunking noise when trying to turn. we are stripin that clutch side of the bike to see if that is the case so i will updates u all later in the week!!
March 30, 200422 yr it is the rubbers on the clutch basket that have gone happened on my mates dads rev3 also some of the rivets buggered up in the clutch some where dont no where they actally are but you just need to replace them and it should stop clonking
