Rear Shock
Does any one know if the rear shock on a 03 sherco is rebuildable as petes is making a strange squishy noise on rebound but is still damping. suspect power washing caused the problem. if it comes down to it and a new one is needed will the 04 fit ,heard its longer but a better shock. cheers lads.
cheers nigel ,you wouldnt have a contact number or address would you.
Check that the bearings and also there seals around the shock area are ok and working fine. There could be a lot of water in them and when you push the shock down your pushing ou the waterout of the bearings. But this is only a guess.
Gavin
Hope you fine the problem. But so times its not a big a job as you think.
cheers nigel.im using the strange noise in my shocker as an excuse for my resent poor riding. :D ill get the shock taken out and see if i can see a problem if not ill get it sent away. :wacko::D
