Abergavenny Ac 1st Round Club Championships: 4th March
The first round on Abergavenny AC's 5 round club championships will run on Sunday 4th March starting at 10h30. There are 3 routes: Sportsman (Yellow) for Novice/Twinshock/Pre-65; Clubman (Red and Blue) and Expert (White). It is being held at Penycraig Farm, Llanwenarth, Abergavenny, on the Sugar Loaf. It will also be the 2nd round on the East South Wales Centre championship for which any member of a centre club can participate. The trial is Open, with no restrictions to club or centre, you will need an ACU licence.
Its at a venue we've only used a couple of times in the last 5 years or so and is a mixture of rocks, banks and trees. Mathew Johnson (C-of-C) has laid out a 15 section lap and seems that the course is weather proof. The directions in TMX are slightly wrong, in that access will be from above the venue, not below via the Foresty Track. Because of the ground some of the sections are close together, but should not be a problem.
To find the venue:
head out of Abergavenny on the A40 towards, Brecon. Go past Neville Hall hospital and it will signed off to the right, down a narrow lane and then heads up steeply to the Sugar Loaf car park, high above Abergavenny. Go up to and through the view point car park and into the venue.
Multimap Link
If you need any further info, call me on 07720 079845
Edited by malcra
to confirm, tomorrows event is still on, Matthew Johnson finished setting out this morning and though slippery its should be fine.
see you tomorrow
Hi Malcra..
I know you are away at the mo?///,.,,but if you see this post, are the results online anywhere...Would like to know how badly I did!! :banana2:
