March 22, 200719 yr the clutch cover is warped on my 06 290 it has leaked oil for ages and lets water in when washing turning the oil milky, gonna try and skim it on a lathe or face it on a flat plate anyone else had this problem and how much is a new cover, (i only have 2.3mm of depth to play with which is the difference between the clutch dissengaged and the inner face of the cover, the cover is warped by 0.5mm between the bottom two bolts so if i can't skim it im gonna need a new one!) Edited March 22, 200719 yr by stump magnet
March 22, 200719 yr will the water pump still work ok if you skim the cover ? is there enough clearance on the kickstart shaft ? i'd buy a new one
March 22, 200719 yr the clutch cover is warped on my 06 290 it has leaked oil for ages and lets water in when washing turning the oil milky, gonna try and skim it on a lathe or face it on a flat plate anyone else had this problem and how much is a new cover, (i only have 2.3mm of depth to play with which is the difference between the clutch dissengaged and the inner face of the cover, the cover is warped by 0.5mm between the bottom two bolts so if i can't skim it im gonna need a new one!) I had the same problem with a sherco, it was 0.5mm out as well, but a liberal smear of silicone sorted it out and it has been no more trouble :-)
March 23, 200719 yr I bounced one off a rock, sanded it on a flat plate, filed out the o ring groove, and it seems fine. Although I haven't tried it yet. Bought a new one, as I recall, it was about $50 dollars. Edited March 23, 200719 yr by titanium
March 24, 200719 yr For that matter, just face it and use the sealer and chunk the o-ring. I will work till the next time you bash it!
March 24, 200719 yr Author how do i post picys there dont seem to be an add atachments thing anymore? Edited March 24, 200719 yr by stump magnet
