May 28, 200719 yr Does the DT250 fuel tap fit the TY fuel tank? Is A$52.00 too much to pay for a complete fuel tap?(from Yamaha) I had a leak from the 'diamond' shaped rubber gasket behind the tap. I have cleaned it all out, but I'd like to buy a new one if possible.
May 28, 200719 yr $AU52 is a pretty normal price for a TY fuel tap. Those diamond shaped seals can be bought separately if that is all that is wrong with the tap. A better tap for TY250 and TY175 is the Kawasaki KT250 tap. About the same price but uses a different idea for sealing which lasts longer. No idea if a DT250 tap is the same as TY250A.
June 7, 200719 yr Author OK, can I go to a Kawasaki shop and buy a new tap? The diamond shaped gasket seems unique, where can i get that from?
June 10, 200719 yr I do know that comparing the DT175 to the TY175 fuel tap are completely different, in size, length and mounting.
June 13, 200719 yr Author yeah I've sussed out the gasket, it looks like I'll have to buy a complete fuel tap unit.
