Tyz Braking Help
does any one know where i can get some new or recon calipers or new seals for my brembo calipers for my tyz? front bleed nipple is seized and rear has blown a seal, any help most appreciated. thanks :thumbup:
Nigel Birkett has recon kits for the TYZ calipers. May also have a used caliper. I'm pretty sure that the caliper is the same as used on other bikes at the time too so shouldn't be too difficult to source one. There's someone breaking a 305 Fantic and a JCM on ebay now and chances are they used the same caliper. Birkett's will tell you and may also have a tip for freeing off the bleed nipple
