Help Required Honda Seeley Swing Arm!
Hi everyone, I have tried to remove the swingarm from my Seeley but i still cant get it out from the frame.
I have removed the Two 8mm bolts from either side of the frame and have tried tapping the bushes but still no luck, any help or tips would be fantastic
regards to all honda nutters Slippo :thumbup::thumbup:;)
Whilst i am here has anyone tried to fit a rear disc conversion ?
Get yourself an old 8mm bolt (longer the better) screw it into swinging arm shaft and hit the end of bolt. 2 points come to mind, 1 if you can't remove a swinging arm spindle, what hope have you got for fitting a disc conversion and 2 why would anybody want to fit a rear disc conversion to a Seeley.
Sorted now ta!! :thumbup::thumbup:;)
