September 12, 200718 yr Hi all, how do we go about taming a sherco 290. Have been told putting slow action throttle on. Changining front sprocket from 10 to 9 tooth and changing the rear sprocket but cant remember what size. Can anyone tell us what doing 1,2 or all three do? At moment it has fast throttle 10 on front and 42 on back and we are finding it a little to much to handle. Thanks Steve
September 12, 200718 yr You don't need to do both front and rear sprocket. Going down 1 tooth on the front equals close to going up 3 teeth in the rear, then you need to buy a new chain. Retard the timing if ya can, plus slow throttle.
September 12, 200718 yr The most effective way to soften the power down is to retard the ignition anything up to about four degrees is ok!
September 13, 200718 yr Fit a slow action throttle. I have an 05 290 and retarded the ignition as far as I could. The bike has nice soft power now. To get the flywheel off the 05 needed a 30mm diameter 1.5mm thread flywheel puller. Got mine from those nice people at Trialsbits.co.uk.
September 14, 200718 yr Hi oke boy This may sound odd. But in the past I rode a 290 for almost 2 years. During that time I was constantly on TC (and TA) asking this very same question. Consequently I
