September 28, 200719 yr Hi everyone ,im still on the look out for some good used stanchions for my 199b, but cant find any ,does anyone no if there is any other make that used the same 35mm fork (stanchions)thanks
September 29, 200719 yr The forks for Bultacos were manufactured by Betor as were the forks used by Ossa. However there were many different stantion types as they were usually knurled where the stantion interfaced with the bottom yolk gripping area. The later the model, the further down the stantion the knurling was made. It may be cheaper just to buy new as the fork sets lying around now command a high price and you may need to get them hard chromed to get them working as they should. Have you tried Bultaco UK? Big John
September 29, 200719 yr Blimey Swooshdave, that knurling is very low, considering you have the lower clamped alloy bottom yolk. I bet "Legs" would know why... Big John
