December 4, 200718 yr Does anyone know what the standard tooth numbers are on a 06 290 Cabestany? Just out of interest what teeth layout do you run? 10 - 42? 11 - 44?
December 5, 200718 yr Does anyone know what the standard tooth numbers are on a 06 290 Cabestany?Just out of interest what teeth layout do you run? 10 - 42? 11 - 44? I did not notice a gearing change on the Caby bikes, I run the stockers at 10-42 which gives a 4.2:1 ratio. A 11-44 combo would give a bit taller 3rd gear for really big stuff at 4.0:1 ratio but make the jump to 4th even greater. I did run a 10-44 on the '05 bike which made gear 4 and 5 much better on the loop, but the '06 and particularly '07 bike does not seem to need any help making the transition.
December 8, 200718 yr I had a 03 sherco 290 a couple of years ago i messed with the gearing to lower 4th and it made 1st, 2nd and 3rd savage and snappy!
