January 30, 200818 yr I have a swb transit which i spend a lot of time towel drying the condensation of the roof any suggestions
January 30, 200818 yr I've lined mind with 4mm ply with roof insulation in between.. nice and warm with no condensation.It also helps with road noise as well..
January 31, 200818 yr Author take the mattress out Is everyone a comedian ! the vans only used a weekends would the rotating type vent work ? i see them on fleabay
January 31, 200818 yr Put a crank up vent in. Most come with a screen in place. They're about $30 dollars on ebay.
January 31, 200818 yr Is everyone a comedian !the vans only used a weekends would the rotating type vent work ? i see them on fleabay Edited January 31, 200818 yr by sectiononecleaner
February 2, 200818 yr Another option is buy some cheap foam backed carpet and some good quality spray glue and stick the carpet to all the flat surfaces on the roof and sides make sure you get the surface clean and dry before you start.
