Bsa Chain Clearance.
charlie prescott
Interesting - I ran both my B40's (trials and trail) with a 520 Chain and had no problems with it fouling the oil seal. This is how it came as standard on a B25 and the frame and engine position are the same..... Unless its because the 14t sprok I used placed the chain plates outside the oil seal whereas the 12t puts them right by the seal??
Hi Guy's
Yes it is the 12 tooth that is the problem. I should have thought about this before posting. With this Talon sprocket the chain sits right down along side the oil seal, another cure I have thought about is to use a totaly sealed gearbox bearing and machine of the face of the oilseal holder. May try this on the next engine.
Regards Charlie.
Please sign in to comment
Sign In Now
