February 17, 200818 yr i have a 2007 Cabestany does any know what the float height should be with the Keihin carb
February 17, 200818 yr 19 mm with carb at 45 degrees. Hunting at idle will be pilot circuit. screw in pilot screw will richen, use range of 1/2 to 1 1/2 turns out. If outside this range change the jet. ShercoH
