April 17, 200818 yr Which is the best exhaust to buy for a tlr200? :banana2:depends how much you want to spend ......judging by your previous posts about 10 bob!!!!
April 17, 200818 yr WES system is a 2 peice setup (mid box and silencer) - Fits TLR 200/250 and apparantly TL DEP system is a 1 piece setup with only the end silencer re-packable- Fits TLR 250 ONLY Hope this helps
April 17, 200818 yr Alter the original,you can finish the end as you want but this works well. http://i259.photobucket.com/albums/hh307/s...june2007003.jpg http://s259.photobucket.com/albums/hh307/s...june2007003.jpg Edited April 17, 200818 yr by superhondaman
April 18, 200818 yr Author WES system is a 2 peice setup (mid box and silencer) - Fits TLR 200/250 and apparantly TLDEP system is a 1 piece setup with only the end silencer re-packable- Fits TLR 250 ONLY Hope this helps There the two I have the choice of, both around the same price too, think I might get the dep one as it's re packable. Also getting a Stainless steel front pipe.
April 18, 200818 yr Author the WES TLR end silencer is also re-packable Ah right, I was told it wasn't, thanks for that.
April 18, 200818 yr Both the WES and the DEP need carefull lining up when fitting,especialy the WES,as it easily rubs through on the inside, with the rear tyre. Look at most used WES rear boxes, and they have a repair where the tyre has rubbed , its close on the shock at the front and close to the tyre at the rear The DEP is a lot easier to fit but may need minor tweaking,and clears the shock and tyre OK, DEP would be my choice of the two. I believe there are also some WAKO style systems that should be available later in the year.
April 18, 200818 yr Wako is very good in comparision to all thats available here in the UK at the moment, but seem to remember someone trying to sell one of their HRC badged stainless systems for over
