May 16, 200818 yr I have seen people with coloured bolts around the engine and just wondered where you can get them from. Thanks
May 16, 200818 yr Had them from here before for my fighters. http://www.modern-screws.co.uk/index.html Edited May 16, 200818 yr by ythan
May 17, 200818 yr Caution, colored ally bolts are NOT for high stress applications! You may get by with them on your motor sidecovers, but that's about it! Stainless will do better in other applications!
May 17, 200818 yr I've just changed various bits on my bike using bolts from a firm called Pro-bolt. The company was fantastically helpful and they can provide you with anything you want (virtually). They supply a lot of the MotoGP guys so are second to none in the quality stakes. Have a look at their website www.tastynuts.com These guys supply titanium and aluminium bolts, specifiying where each should be used and have done a couple of kits for some Gassers. You'll be in BLING heaven when you see what they can provide you with!!
