August 25, 200818 yr I have a honda TLR200. I have removed the rear and front lights and battery but I want to also remove the ignition barrel & therefore the rest of the wiring loom from around the headstock so I can fit a number board where the headlight was. If I remove the wiring loom which is also earthed & connects to the coil wiring will it still run or will there be a short somewhere. Obviously CDI & coil wiring stays untouched but Can I also remove the regulator as is this only to regulate current to the lighting to stop bulbs blowing? If anyone has done this could you advise me please, thanks.
August 25, 200818 yr Disconnect the ign switch first as most Jap bikes will run when you do this. You don't need the regulator either I don't think. You will also keep the kill switch. Edited August 25, 200818 yr by bo drinker
August 25, 200818 yr Author Just disconnect the ignition key barrel loom attatchment then? Do I need to re-earth anywhere?
