September 22, 200818 yr What steps are you guys taking to prevent this? Currently, the thropttle cable, clutch line and kill switch all get squished when the bars are turned full lock to the right? Rerouting the cable doesn't work as they are too short. Thanks for the help.
September 24, 200818 yr What steps are you guys taking to prevent this? Currently, the thropttle cable, clutch line and kill switch all get squished when the bars are turned full lock to the right? Rerouting the cable doesn't work as they are too short. Thanks for the help. You could buy a kit to make up a longer cable. (www.trialsbits.co.uk amiungst others.)
September 24, 200818 yr A shop in your area can make you up a longer cable. How far are you from Manchester Honda? Or call RYP and ask them to make one for you. Edited September 24, 200818 yr by motofire
September 25, 200818 yr Author yes SY250R 2007 Stock bars The bars are rolled slightly foward Neither levers are mounted tight to the grips for the exact reasons you mentioned. I don't understand why stock, I have this problem? I emailed RYP, 3 days and still waiting for a reply.
