September 24, 200818 yr does anyone know the small end bearing size for a 06 290? can they be obtained from a local bearing dealer? ta.. gassar
September 24, 200818 yr Cant answer your question on size sorry...but, I get all my bearings for my bikes from a bearing dealer. They are half the price(at least) and sometimes you can get better quality bearings.
September 24, 200818 yr Go to www.shercousa.com Look under the tab: service info In there you will find the parts manuals, and the bearing size is probably listed. When you say small end bearing size are you referring to the crank?
September 24, 200818 yr Author Cant answer your question on size sorry...but, I get all my bearings for my bikes from a bearing dealer. They are half the price(at least) and sometimes you can get better quality bearings. that's the point without the size a bearing dealer is not much use??
September 24, 200818 yr Author Go to www.shercousa.comLook under the tab: service info In there you will find the parts manuals, and the bearing size is probably listed. When you say small end bearing size are you referring to the crank? no the bearing that connects the piston to the con rod via the gudgeon pin?
September 25, 200818 yr The Sherco manual says (KBK 16x20x18) although that is for the 2007 model. The bearing is not listed in the 2006 manual.
September 25, 200818 yr that's the point without the size a bearing dealer is not much use?? Werent you looking for help on 2 points? Sorry I wanst much use.
