October 19, 200818 yr I discovered that the OD of the VM26 Mikuni bellmouth is just a bit less than the nominal (unstretched) ID of the Miller air filter's integral boot. I made a small adapter to press onto the bellmouth to increase the OD to the point that the boot has to be stretched to fit. It wasn't a big project, but without it the airfilter wasn't staying attached, even when clamped. I thought it was worth mentioning in case someone else had to deal with this same combination of parts. cheers, Michael Edited October 19, 200818 yr by MichaelMoore
October 19, 200818 yr Author Here's the old one: If Miller made that filter to fit the OEM carb, then an OEM filter boot might also have problems mating up to the Mikuni. cheers, Michael
