November 2, 200818 yr i rode my new 09 3.2 4t for the first time in a trial at the weekend and after the first lap it over heated and blow the water out od the overflow. when the bike was going well on the first lap it was very very powerfull. but the fan was nearly going all the time. has any one had this problem with the 4t bike
November 3, 200818 yr If the fan is working and making hot air, chances are the rad was too full to begin with. It need expansion room at the top, coolant level just over the coils, or they will expell any excess. Hope that helps!
November 3, 200818 yr Author The rad was not too full and when i check when i got back to the van there was very little water in. i took the screw out on the side of the barrel and nothing came out.
November 4, 200818 yr i rode my new 09 3.2 4t for the first time in a trial at the weekend and after the first lap it over heated and blow the water out od the overflow. when the bike was going well on the first lap it was very very powerfull. but the fan was nearly going all the time. has any one had this problem with the 4t bike sounds like no circulation, check the water pump cheers
November 4, 200818 yr hey, did you ride in map 2? i know a gasgas will boill over when used hard in the wet weather setting so mayby a sherco does this also? my 4t (2007) gets verry hot to fan continuesly running than stops for a verry short while (seconds) and that runs again is thins normal? my cota 4 rt didn' t do this mayby the interval in whith the thermostate switches on/off is to small? regards bob
November 13, 200818 yr Author i tock it back to the dealer he had it for a week, i have now got it back he said he but a new ignition on it, i am not well at moment so i will not get out on it this weekend but one thing that the ignition helped is it was very hard to start when cold but it now starts second or third kick. i have tryed it every day from i got it back and it starts all the time now
