December 12, 200817 yr Hi there I have a 2008 sherco 290 which has a switch on the bars with map 1 and map2 on, could any body enlighting me and tell me what the differences are between these? Many Thanks
December 16, 200817 yr is this the sameon the 3.2 4t? i can only feel a difference in the high revs (on a 290 i once tried biggest change was also in high revs in the softer map the bike didnt rev high) regards bob
December 17, 200817 yr is this the sameon the 3.2 4t?i can only feel a difference in the high revs (on a 290 i once tried biggest change was also in high revs in the softer map the bike didnt rev high) regards bob Seems to be the case! i have been confused as well from both seat of the pants and reports! Personally, I think one would be better off to dump the switch totally, go to base timing, and adjust accordingly if needed! Edited December 17, 200817 yr by copemech
