Honda Tlr250r
looking for help locating parts, i require a complete chain tensioner, petrol tap lever, and side panels.and a front sprocket suitable for easy trials
the bike has been rebuilt and is in brilliant condition just need these parts to complete. would be grateful of any help. john
Try Bat motorcycles London. They order parts for these from Japan Google them for contact details/
For a front, try a Suzuki Beamish sprocket with 10 teeth
It wont fit..... but if you have a Dremel or similar with a sanding disc you can open the inside teeth out the few thou needed, the tooth shape etc is the same they just are a tiny bit long
some i have had almost fit straight on, but it doesnt take much to open them out
you will need a 4mm (approx ) spacer behind the sprocket and a circlip to hold it all on
check your personal mail...
