January 2, 200917 yr hi new to trials the fan on my scorpa easy 1998 does not work had the stator rewound and new rectifier still not working could anyone help with wireing diagram or any advice cheers kez
January 2, 200917 yr Hi On the top of the cylinder head there is a brass thermo switch, remove the 2 wires and connect together. the fan should go (engine running) if not you probably need new thermo switch. Car spares shop the on and off tempretures are printed on the switch. If the fan does not go with the wires connected, probably fan. Many jap road bikes have same fan so try breakers. I got one and had to drill out the three mounting holes to accept the rubber mountings on the easy. Easy to do. For loads of info on the mighty Scorpa Easy try thehellteam.com. Hope this makes sense and helps. Pete
January 3, 200917 yr Author hi pete had the fan runing off car battery also connected thermo wires together still nothing thanks for your help i will keep trying to mess about with wireing cheers kez
