Amal 622 Mark 1
I have a Amal 622 Mark 1 on my cub what pilot do the gurus out there recommend
Vinnie
Hi Vinnie
i have just fitted a new 622 on my 200cc cub, i have had it running faultlesly with a 110 main 25 pilot middle clip on needle, baisically as it came from Surry cycles, only change i made was to use a 2.5 slide.Also i checked and set the float hight(which was lower than recommended) Maybe because its new and not worn yet? but so far it's ran better than either the Dellorto or Villiers i have tried previously, contrary to other peoples experiance with the 622?
Edited by superhondaman
  • 2 months later...
HI
What size needle jet do you have fitted to your cubs 622?
Rgds triton
Hi Vinnie
Are you sure the needle jet you have fitted is a 30, My present one is 105 and previously 106?
rgds triton
Sorry blond moment that was pilot jet
vinnie
