January 19, 200917 yr Can you help me with fitting a cub hub in a set of b50 front forks? Do you have to make a new spindle or are there other ways around it? Is it a good idea too cut my c15 frame to raise the engine for more ground clearance? do I live with it or go for a faber frame? Any help much appreciated.
January 19, 200917 yr Can't help with the forks/wheel but unless you're handy with the cutting and welding gear, if you can afford a Faber frame go for one. I've seen a picture of the latest one with the bottom frame tubes (still oil in frame) and it looks a lot nicer than the old one. Raising the engine, dropping the subframe etc. is a lot of fiddly work, Faber is the easier option
