Keihin Carb
My sons 290 cabby has a problem of flooding it's keihin carb through the overflow. Apparently these carbs have a problem doing this so i've changed the spring loaded needle valve without any success .So my question is this ,can anybody tell me the settings for the floats,where it is measured from and please, if possible, with pictures or a link to a website that does have pictures ? ( Other than that this bike is awesome ! )
Thanks In Anticipation
Phil
hey
my 320 does it to float set at 18 mm (i tought)
but still a great bike starts good to (2007)
pilot jet is 48 mayby a bit to big (in low revs the bike is not 100%)?
regards bob
keihins and okos are a problem here. float height is 19,5 mm. Some bikes on this setting will starve fuel when hitting a step at 19 or 18,5 mm (float heigt not step height ,-). google the keihin website to see how to set. mine leaks on the sidestand at 19,5mm but not when riding
HTH
lee
hey
tnx for the replay!
my carb only leaks now and then mostly it works great, just sometimes the fuel streams out of the overflow pipe and then it stops again for some time
i gues its a sticky needle or something like that (floats rubbing agains something?)
regards bob
