Sherco
hi when i start my sherco from cold sometimes it wont tick over and just die's out and cuts out and then
other times it fine, i dont no wht the problem is.
Josh.
Sounds like the pilot jet is either plugged with dirt or the plastic tube inside the tank that fits on the filter has not been modified - check www.ryp.com - Ryan Young's website - he has all the service info available. or in the UK give Rathmell's a call. - either way it's a simple fix.
i think that it could be the stand pipe that hasnt been modifed like you said i will have a look at it tomorrow
thanks Josh
