October 28, 200422 yr HI Could anybody tell me if there is a special tool to remove the rear wheel bearings The front ones where dead easy. The back are a major nitemare. Thanks ShercoHK
October 28, 200422 yr I asked about wheel bearings a few weeks ago under the title 2000 wheel bearings theres a few tips in there: www.trialscentral.com/forums/index.php?showtopic=2223 Mick
October 29, 200422 yr Yes, Ryan www.rypusa.com has an excellent brass drift that is precision machined to do the job. Makes it quick, easy and effortless. There are other means out there, and I have several, both less and more expensive, but I do not believe you will find anything as quick, easy and precise as the set of drivers from RYP.
October 29, 200422 yr Author Hi Alan Thanks for the info. That sounds like just the trick. Thanks Shercohk
