Rear Brake On Not? You Tube Vid!
just been watchin a you tube vid, I have been tryin to do this on my bike on a smaller rock but am i doin it right?
When i get the back wheels up on the roc is there any rear brae involved?
I play about doin trials on my pushbike and of corse i would have to use the brake!
Thanks
Good Video.
Robert
Kinlochleven
Edited by HDfilm
there two ways to do it that i use. the first is to hold the clutch and throttle so it keeps the bike in that position and doesnt bring the front down or the other is to like you say hold the back break. the back brake method would be better as it will keep your front up longer and hold it up aslong as u lean back enough other wise it will go down fast! and also when you drop off you need to apply throttle so that you land back wheel first
5* video well done. You welcom to post on my www.scottishproducttv.com
Robert
Kinlochleven
What you on about dude?
I thought i would need the back brake, i find it hard to use rear brake when doin it tho :moon:
depends entirely on how steep the front wheel is! if its gone past the point of no return and you have a little bit of forward momentum, a bit of rear brake should bring it back to earth. but most of the time I find I dont need the rear brake. just good throttle and clutch control at the top. if you are looking to get some real rear wheel height your front wheel has to be fairly low and you need to use tonnes of body and a few revs to get it to fly high. this is usually when you would need the rear brake.
practice doing rolling "jap-zap's" (as ryan young would say) and grab your rear brake at the top. once that becomes more natural it shouldnt be a problem.
All the best
Tom
All the best
Tom
This would basically be doin a bunni hop?!? Ill give it a go tomo!
Cheers
If you really want to learn it, put a kickr rock a couple feet out to help your rear get some height.
The front never touches it mind you, lift the front, punch the rock, pop the clutch and let the kicker help the rear up!
iF DONE CORRECTLY, YOU CAN GET THE REAR HIGHER THAN THE FRONT AND DO A "NOSIE " OFF THE ROCK!
Try that Tombo! :moon:
Good advice, ill give it a shot next time im out!
feels and looks great when its done right, becomes painful very quickly if the front is too low......
Tom
I aint really ready for all this jumping up stuff yet i dont think, I can manage a vertical rock of about 1metre in full control atm,
Is jumping in the deep end a good idea? I seem to learn well by my own mistakes!
