May 17, 200917 yr Hello - I just purchased a new OSET 12.5 for my nearly 4 yo son (and apparently just under the wire - as the website no longer sells the 12.5). I was wondering what kind of grips to purchase, what size and how to install them. My son's hands are kind of small and reaching brake levers has always been difficult. I would appreciate any info that you folks can pass on . Thanks! dylandog
May 18, 200917 yr As far as the levers...you can adjust them so they are just off the grip by using the setscrew in the lever perch. For grips...I like to use Mini size grips. I install using an air compressor. Watch the video below, it will help but I personally do not use grip glue. I use alcohol to slide the grip on then I safety wire the grip.
May 18, 200917 yr Author thanks for the link... going to try this ASAP. Now I can appreciate the air compressor! Cheers
