May 30, 200917 yr Its time for a oil change all around can any body help I need to no the amount of oil I need to put into my front forks on a 04 sherco 250 Thanks matty
May 30, 200917 yr Its time for a oil change all around can any body help I need to no the amount of oil I need to put into my front forks on a 04 sherco 250 Thanks matty Hi mate, See here for a guide. Waynes Corner I believe you should put less oil in when you are just changing as you never get the full amount out, where as rebuilding them they will be dry.
