Cub Dellorto Carb Conversion
Hi folks, anyone know where I can get the necessary bits to put a Dellorto carb on my cub??
Thanks in anticipation.
Cheers, jt
Hi,
Try Eurocarb, Kentwood hill, Reading, Berks. They import Dellorto and can sell you a PHBL 22mm or 20 mm set up fo a trials cub for around
Hi Paul, thanks very much for that it is much appreciated. How about the bit that connects the carb to the engine as I assume that the manifold I have for the Amal will not work for the Dellorto?? Thanks in anticipation jt
Hi,
Dellorto can supply the inlet rubber for their carb, and a K & N type filter from stock. You can turn down an amal bolt on manifold to accept the delorto inlet rubber
Regards Paul B
Hi Paul, Thanks again for your help, much appreciated. Have a good week-end. Cheers jt.
